Dodge Trucks \  Front bag cups for dakota
Dodge Trucks Make Specific
views 897
replies 16
following 6
Wolf37   +1y
i have a 2004 dakota and need a set of cups to mount the bags to. I have the stock upper arms along with DJM lower arms. would i just be able to use a set of S-10 cups or what do i need? What are all of you using?
baggednomaman   +1y
hey bud i just fabbed some cups for a buddy of mine and he is layin low in his 02 dakota. you asked if you can use s10 cups i think you can if you drill some holes on your lower control arms, but the bags wont (sit) right. I also recommend front shock relocaters bro. I made his bag cups from 3/16 thick 5 inch tubing and some bag plates from suicide doors. It seems like nobody makes dakota parts. hit me back if you have any questions
Wolf37   +1y
why wouldn't the bags sit right with the s10 cups.... my lower arms are DJM so they have a flat pocket to mount the bag. so unlike the stock arms i wouldn't have to angle them
bdroppeddak   +1y
i use a normal cup for a fullsize chevy up top, and plate the lower arm. get your cups @ gravity-werx.com. you can use cups top and bottom if you want. just get some made for a f/s chevy.
Wolf37   +1y
thanks for the info...you are the first person to give me a definite answer on a cup that will work for sure. Thanks again
baggednomaman   +1y
sorry i didnt reply earlier i have bagged 2 dakotas and i have angled the top cup a little and the lower cup to. but i havent put lower arms on a kota yet. good luck with that truck bro.
Wolf37   +1y
so do you have the stock arms? will i need to angle my top cups also...is it required for the stock arms? Thanks for the reply man
baggednomaman   +1y
yeah man the top cup at a angle and the bottom also if you use cups with your lower drop arms you can weld a 1/4 inch plate and drill a 3/8 hole for your bag, i dont have the stock arms any more.you dont have to use you stock arms.
bdroppeddak   +1y
there is no need to angle the cup, i put 30k miles on my truck bagged with flat cups up top and plated lower arms. i did another and built tubular arms and still used a flat cup up top.
baggednomaman   +1y
Really? i tried flat cups too. and i have also tried angled they work about the same except that the upper cup not angled wobbled for some reason? thats why i started to angle the top cups. either way works i think.
