spindles
spindles
j-bird
do you have to put spindles on when doing a bad set up (layin fram) or is there a way around it? on a 93 astro
j-bird
anyone? just looking for alittle help!!
whynotfab's avatar
whynotfab
Probably mainly depends on wheel/tire combo
j-bird
damn ricky i was just about to im you! i'll be running 20x8.5 or 20x9 all the way around
suicidedoor86's avatar
suicidedoor86
yep you probably will for it to lay on 20's,you will have to cut the wheel wells right out probably too.make sure you use a small ass tire in the front.I ran 18's and it layed nice with drop spindles.for the 180 bucks or whatever they cost the spindles will also minimize negative camber
j-bird
thanx......im on the search for spindles!!! thanx guys
MBlazer
I have 28in tall tire in the front of my van and its about an inch from layin crossmember so I think you could lay crossmember with a 20 and small tire with out cutting the inner fenders out.
s10
last post by baha +1y
