4.3 MOTOR QUESTION
jmzcustomz@sbcglobal.net's avatar
4.3 MOTOR QUESTION
jmzcustomz (jeff)'s avatar
jmzcustomz (jeff)
OK S-DIME GURU'S.... What if any aare the differences between a regular 4.3 out of a 94 s-dime and a 4.3W out of a 4X4 94 s-dime? Please help we are trying to get it running asap.
9
94NissanLaysDoor
oil pan
david49910
also, depends on the VIN of the 94 S10.
Vin Z= TBI
Vin W= Multi Port injection
and as stated above, the oil pan hangs lower on 4x4s
SCOOTER's avatar
SCOOTER
the vortec heads have a different angle for the intake but the valves are the same size in the heads and the vortec has a balance shaft in it above the camshaft to balance the engine out.
pat2low
genral the 4wd have about 5 or 10 more hps over a 2wd engine
bagdb2200
Originally posted by pat2fast
genral the 4wd have about 5 or 10 more hps over a 2wd engineThe S-10's 4.3's had the same HP whether it was 2wd or 4wd. There was a couple years it got increased because of improvements to the motor.
V
vinnysmini
I have a 2wd 4.3L Vortec Type W motor on my truck. My oil pan sits about a 1/4" off the ground if that. Supposedly the W type motor was made for towing and has more torque and a little bit more hp. I know that the air filters and stuff are different on the motors but it's pretty much the same motor and block. Maybe a few extra hp if that. However, with my motor I didn't have to lower my motor mounts or anything and I bodydropped my truck and am running the stock hood.
bmxr4life87
Straight off of s10forum its the "Holy Grail Thread"!!! Just about anything you could want!!!
http://www.s10forum.com/forum/showthread.php?t=131868
bagganddrag
vin w 240 hp vin z tbi 165 hp
