leaky pinion seal
leaky pinion seal
tenagator avatar
tenagator
my pinion seal was leaking, so last nite i changed it and it still leaks? wtf. i checked the yoke it didnt seem bad or worn to the touch but i knwo maybe it is and u cant see it.or is i t possible the vent on the rear is clogged up? i did a lot of cutting grinding painting on the rear so maybe it cannot vent? or is it possible i have to much fluid in the rear?
SCOOTER avatar
SCOOTER
what kind of truck or rearend is it and how much grease did you put in there?
tenagator avatar
tenagator
its a 92 yota pickup.
well i put the oil in and it came out the filler hole so i put the plug in. usually u put ur pinky in and if the oil touches the tip of ur pinky ur good. maybe i have to much in there?
SCOOTER avatar
SCOOTER
u let it leak out of the fill hole until it quits leaking but you don't have to much in there. so i would check your vent plug/hole/hose whatever it may be. if it is clogged i would clean it, cause the pressure can build up in there pushing fluid out of the front seal around the pinion. so you're probably right about the vent being clogged.
