Isuzu \  removing the air pump
Isuzu Make Specific
views 255
replies 4
tealrangerpmp   +1y
Hey guys well i just bought a 91 isuzu and have it bagged but i am trying to eliminate any extra baggage off the truck so i was wondering if i am able to remove the accesory driven air pump for emissions. I am not worried about inspection i live in upstate NY and i can get it passed anyway.Thanx in advance Joe
mmrcustoms   +1y
pull it off and block the hole in the man.with pipe fittings from home bepot the ones with the hex shaped top that u screw in
tealrangerpmp   +1y
So will it affect the way that it runs at all?
mmrcustoms   +1y
u might have to adj. teh carb setting and timing a lil but it should not
sponge splawn   +1y
Hey bro! What size engine do you have? I yarded mine out so I could fit the 20's and to ad an engine drivern compressor. Mine has the 2.6 ltr. I plugged the holes in the manifold like mmrcustoms said to do and I didnt have any problems, except, you will need to put a swall rubber cap over the hard vacuum hose that is attached to the front top of the valve cover(right above the fan).
