Mazda Trucks \  need a little help
need a little help
Mazda Trucks Make Specific
views 223
replies 14
following 10
lomitsu   +1y
Edited: 5/16/2006 11:05:56 AM by groundbound96
ok i had aim spindals and i switched them out for factory ones and fliped the ball joints and now dosent lay out for shit any one have an idea as what the problem could be
imreal44   +1y
okay..... and?? are you wondering why or just need to vent?
low mazda   +1y
well you took off 2 inch drop spindles, and put on factories which raised your truck 2 inches, then you flipped the ball joints which dropped you back down about 1/2 an inch. NO NO on your part...
what are you doing with the drop spindles?
livinlow   +1y
look for binding in the lower control arm and notch out the area that hits the frame. make yurself some spacers and angle you're upper balljoint so it doesn't bind as much. theirs lot's of things you can do.
all depends were you're upper bag mount is located on the frame aswell, if it's not on the upper most part of the frame you better put those spindals back on cause you aren't ever gonna lay out for shit.
lkrayzie   +1y
yup, first thing ide check for is if the mounts are too low and compresses the bag before you lay. if thats the case, rebad it or reinstall the drop spindles
lomitsu   +1y
i am not doing anything with the spindals and yes the bag mont is too low on the frame
lomitsu   +1y
can some one post pics of the front set up on ther mazda
lomitsu   +1y
no one has any pics?
Twisted Galant   +1y
y did you take them off?
lomitsu   +1y
Edited: 5/16/2006 9:50:28 PM by groundbound96
i took them off because aim is gay and dosent sell replacement ball joints because the factory ones dont fit in the spindal
