abs lightcheck engine light o/d light ruff shifting wtf?
sslinky
all at once my abs light came on and the speedo stoped working and the check engine light came on my auto 00 ranger wtf gives? also at the same time the o/d light started blinking at me and shifts ruff, sometimes ill shut the truck off and start her back up and it just wont even shift into third unless i do manual from 1st 2nd into drivewtf is going on?!?!?!please help!!
msturg's avatar
msturg
that sucks man, i'm sure james shall come to the rescue
d4k0t4
Goto Autozone and get them to hook a computer to it to see what prob code comes up
droppedtoy
May sound stupid, but check and make sure that you have proper battery voltage and the alternator is properly charging your electrical system. Sometimes the different control modules can act goofy if they do not consistantly recieve the proper voltage. Me personally, I usually see that happen more with european cars, but its possible in yours too. Thats a good starting point to check before dropping a ton of money at a dealer.
DeepSouthS10's avatar
DeepSouthS10
i am pretty sure that when the o/d light is flashing, that indicates a transmission problem.
project94
I'M NOT A MECHANIC OF ANYTHING BUT IT SOUNDS TO ME LIKE A BAD WHEEL SPEED SENSOR, THAT WOULD CAUSE THE ABS LIGHT, BAD SHIFTING/ SPEEDO NOT TO WORK. GOOD LUCK
mrbjk1
Yeah if your OD light is blinking then there is something wrong with the tranny. I had that happen on my f-450 and my f-250 The 450 just needed a new torque converter $850 and my 250 needed a whole new tranny $3000. So good luck BTW if you take it to a local dealer they may read it for you for free. Thats what they did on mine the guy just came out and read the codes to the tranny in the parking lot.
grafix's avatar
grafix
Honestly, I had a 99 Ranger did the exact same thing and I thught the trans took a dump. However, as it turned out I had a failed input sensor (speed) on the transmission. Basically a little over a 100 bucks later and never had the issue again.
Also, should have looked first, but if you are bagged and not running wheel wells in front you need to look at your wiring harness that runs over the left tire. Rubbing through those wires will do the exact same thing.
bodydropped85's avatar
bodydropped85
but yea fuck autozone, they cant read tranny codes. sounds like the speed sensor in the tranny took a dump.
Transmission Speed Sensor, A/T 5R55E 4 - Speed Sensor XW4Z7M183AA $20.05 Notes 5 - Output Shaft Speed Sensor F7RZ7H103BA $28.73 Notes Labor SkillLevel Mfg.Warranty Standard Transmission Speed Sensor, A/T Replace 5R55E B 3.2 4.6 get the code scanned by someone w/ at least a snap on or OTC OBD II scanner.
