Dodge Trucks \  94 Mighty Max help
94 Mighty Max help
Dodge Trucks Make Specific
views 160
replies 3
draggin93   +1y
Looking for some suggestions for my suspension. Biggest concern is where to start with the front end for the bag mounts ? And does anyone one make lower control arms to delete the stabilizer bars ? The tranny cross member has been replaced with a new one so it won be in the way to lay frame. Mid crossmember removed, and im waiting on the notch from suicidedoors.com to get here for the rear..any suggestions ?
droppedmitsu   +1y
for the front you're gonna have to cut away 1/2 to 3/4 of the spring pocket. then you can either use cups up there or torsion bar bag brackets
joe558   +1y
i got a few pics in my profile, i dont have a pic of the lower control arm, i just made an "A" out of the stock lower
rimtucker   +1y
For the front on my 91 we trimmed the front spring cups just enough so they would not rub on the bags ... i have had it like that since '95 and just last year a bag finally went out not sure why though .... used the 2 shock mounting holes to mount the bottom plat and used the s-10 cups which worked for the top mount ...(they didnt have Mitsu upper cups at the time I bought the kit) well hope this helps .... let me know if you have any other questions. ..ill try to help
