Ranger fuel tank help
skankinandy@gmail.com's avatar
complexdesigns's avatar
complexdesigns
I have moved my factory tank into the bed and can only use the larger hose so I capped the other. Works fine until fillup when it spews out. Any idea as to how to alleviate this problem?
prymertyme's avatar
prymertyme
i'm assuming you are talking about the vent up to the filler neck...it allows air to escape as the tank fills, but since it is behind the cap, it stays sealed when the cap is closed.
best thing i can think of is to either find a way to tee it back into the filler hose, or pump the fuel slowly, so air can escape through the filler neck. it must remain sealed, though, due to the way your fuel system works.
pootytang
um, you capped the breather? need to know where it spews out of, and what exactly that hose went to. it you capped the breather thats bad, it lets vapor goto the vented cap.
complexdesigns
Vapor goes to the charcoal canister, I attempted to vent it at first but it threw a cel. I am thinking I will just make it like a little red can and throw a vent off or it with a cap on it.
weave's avatar
weave
The problem with using the vent to fill is that eventually the gas will eat through it right above the tank.
complexdesigns
I am filling it through a marine filler right into the factory location, its just not vented for fill-up.
BodyDroppedNikes
on mine, i extended all the hoses when i moved mine into the bed of my Ranger and i dont have a problem at all.
