dssur
Corey: An RX7 in tank pump and sender unit will drop right in, they are built more reliably than the truck units. If you dont want the intank pump (its 50psi and wouldnt work with a carb anyway, just cut your pickup tube off your old unit and use the rubber coupler to replace the in tank pump.
There is even a low fuel sensor on the RX7 sender, you could hook it up to a warning light!
