4 link and axle question
drew.berry@wku.edu's avatar
onebadkota's avatar
onebadkota
any recommendations on a kind of linkage to use for the rear set up...2000 dak....I need to get lower in the back....Also, im sure the axle has to be shortened...is there anywhere around bowling green ky, or somewhere in ky or tenn, surrounding areas???
Also, i guess im gonna need a fuel cell...would a 15 gal. be a good one to go with??
ramsey's avatar
ramsey
Suicidedoors.com will make a 4-link to your specs, and you can put your bags on the bars. For the rear end, i sent mine to moser engineering in IN, they narrowed the housing and custom built shorter axels, not terrible priced either
whynotfab's avatar
whynotfab
suicidedoors.com or gravity-werx.com definitely
9
98dakota20
you can use a cantilever from kp if you dont want to put the bags over the axle. i have one for a full size chevy. i forget what year its for.
gravity matt's avatar
gravity matt
AiredOut's avatar
AiredOut
I deff recommend gravity-werx. I got a couple 4 link bars from them a few weeks ago, and they are very nice. I was expecting quality, but their nicer than i thought they would be.
unologoat's avatar
unologoat
suicide doors, silverstar customs, kp, or extensive. I like all of them. 15 gal is fine I think. I have a sixteen and have no probs with it. I recommend aluminum or stainless. I just dont like the plastic(mine). Strange will do it. I recommend an aftermarket ford 9" from summit or ebay, or jegs, etc. different stock lug pattern but can get anything if go aftermarket..moser,strange, so on. Check for driveshaft length also. May need to shorten it depending on wheel size. l8r
