Isuzu \  cant get it to run right
Isuzu Make Specific
views 275
replies 7
following 7
sukntire   +1y
Ive got a 94 izuzu that i cant get to run right ot save my life. it will sit and idle fine but as soon as I try to drive it it spits and sputters. it has a weber carb and brand new plugs wires cap and rotor. im at a loss ive double and triple checked the timing and i know its right. some one please help me.
John   +1y
What about fuel mixture, possible water in the fuel. Don't know, just a guess.
toybodyparts   +1y
check vaccums
CompleX   +1y
or check coolant temp sensor
DRAG-IT   +1y
Edited: 6/4/2006 5:28:06 AM by DRAG-IT
Check your fuel filter to make sure it is not clogged, a lot of times it can get enough fuel to idle but when it tries to drive it can not get enough fuel.
bobby7m   +1y
chek the fuel pressure. Mine was a clogged fuel pump.
sukntire   +1y
thanks fir the help guys
92LOWYOTA   +1y
if this is a new carb, make sure it is jetted right and not to rich, might have to overhaul the carb also. If the fuel filter is not clogged check that also. or there might be a vaccum leak somewhere like the carb gasket or somewhere else
