Chevy/GMC Trucks \  wiring l.e.d. tails?
views 140
replies 5
following 5
dimebagged   +1y
i have a 95 fs chevy. installed avs leds. wired them up, and blinkers dont work. why? on an s10 i had fbi leds, and had to keep the factory taillight and splice in the wiring for the leds, and they worked fine. anyone familiar with this?
Dragthatchit   +1y
u use there T.A.C. box to convert them to a three wire led, not just a two wire like most usually are??
dimebagged   +1y
yeah i used the harness it came with, from 2 leads to 3. still hving problems tho.
c mau   +1y
Just find out which wires go to wat..i mean i know that sounds dumb and pretty obvious..but find out whihc is the ground which is the power and which the signal jsut by testin it..leave the stokc light hooked up and cut one wire..see what it does..and so forth..or u cna find a wiring diagram for the stock tailights and go that way.,..whichever u choose to do..
clean cut creations   +1y
I have had to install a no load blinker can on some projects. That usually works because the voltage draw is so high from the leds that it overloads a stock blinker can causing it not to work.
chevygurly   +1y
give me a call and i can help you...i work at avs 559-486-5444 clean cut may be right.
