drop spindles and 15" wheels?
cris@gravity-werx.com's avatar
bdroppeddak's avatar
bdroppeddak
ive heard mixed opinions on running aluminum 15" wheels on an 88-98 with drop spindles. i know it wont just bolt on without cutting the arm, but ive seen several trucks running stocks with drop spindles. did you have to cut alot of the arm?
cookiemonster13's avatar
cookiemonster13
if i remember correctly cris you just have to cut the lip on the bottom side of the control from the ball joint edger area to about 4 inches back was plenty.
bdroppeddak
hm... wonder if this will compromise the integrity of the arm.....
lo75lux's avatar
lo75lux
i didnt feel like cuttin my arms wheni got spindles, so i just gott 22s for the extra clearance
bdroppeddak
yea i did the same thing, but i wanna run the stocks because ive worn out my 1st set of front tires already and at 200/tire id rather just put the stocks on it right now.
bdroppeddak
aight, got the wheels on, anyone else have to add spacers to clear the tie rod? i added 1/4" of spacer, and it rubs if i air the truck down tuckin like 3" of tire, but i was drivin the truck 1-2" off the ground with the 22s, so i wanna do the same with the stocks
