Dodge Trucks \  HELP all done but i can't steer it!
Dodge Trucks Make Specific
views 173
replies 7
following 5
layedouton22z   +1y
I am having a big problem with the steering on my bagged and bodydropped 2000 ram. when i raise it and lower the front it sucks the tire in about three inches....how or what has been built out there to take care of the problem modified tie rod ends? please help...
cantlooswit22s   +1y
rebuild yuorr tierods with hiems and spacers.thats wat i did to mine.just make sure the hiems are STRONG
layedouton22z   +1y
I appreciate the help but do you have any pics or can you elaborate on that?
because right now steering---------> steering---------> steering---------> steering---------> steering---------> steering---------> steering--------->
cantlooswit22s   +1y
^^^^^let me see if i can dig the pics up..
eks10BDRG-N   +1y
which set of tie rods are you talking about. didnt you make a dozen ronnie.
cantlooswit22s   +1y
stfu j...no,2. but it works now dont it? lol
BUILTON24S   +1y
on my chevy i had a machine shop make me some adjustable tie rod bars out of 1.25" solid rod drilled and tapped both ends one reverse one regular and put notches inside the rod so with the turn of a wrench u could easily tighten and turn to adjust toe..used hiems with misalignment spacers at the spindle had to drille the original tapered hole out to fit about a 5/8 bolt i believe..i also heimed the end at the rack cut the orignial bearing off the end of it inside the boot tapped that had a piece made to thread into it with tabs on it to slide a heim into i mounted it vertical so i had no limitet up or down..this was all on a chevy but u get the general idea
fatheadjames   +1y
^^^^Got any pics of this? I kinda of understand what your saying but a pic would help alot.
