Air Ride Suspensions \  bag questions, need help.
Air Ride Suspensions Q & A
views 303
replies 6
following 5
35hundo   +1y
Hey Im trying to find out the different heights of a 2600lb firestone bag. Fully compressed, fully inflated, partially inflated. can anyone tell me this or preferably a site to hit that will tell me everything, setting up suspension on tube frame soon and need these things. Thanks.Josh ///RA FL-PA
ir078607   +1y
I pulled this out of the firestone catalog. I dont know the extended dimensions.
35hundo   +1y
Thats cool, I tried to Download the firestone catalog wasnt happening for some reason.
Josh ///RA FL-PA
ir078607   +1y
It shows on airgasm kustomz to be a 9" max height. http://airgasmkustomz.com/mcart/index.cgi?code=3&cat=2
mmh2006   +1y
slamspecialties.com
Max Dia 8" @100psi
Min Height 2.8"
Max Height 7.7" @100psi
35hundo   +1y
conflicting specs huh. Slamspecialties.com says max height 7.7", but airgasmkustoms.com say Max height is 9".
Josh ///RA FL-PA
whynotfab   +1y
*4 The Firestone AirSprings have at least one inch of additional stroke above these numbers, butFirestone does not recommend operation in this range because of possible rubber to plate separationresulting in failure.
That's why you came across two different specs.. hope that helps.
