Air Ride Suspensions \  question about a panhandle bar
Air Ride Suspensions Q & A
views 164
replies 6
following 7
bshot_98   +1y
I have a panhandle bar installed on my 96 chevy fullsize. when I installed it I had 18 on it. Now I have 22 on the truck and when I go around a curve the tires it the inside of the bed side. I had the rear narrowed 1 1/2 on each side. I was wondering is there a way to adjust the panhandle bar so it won't hit
Low_SST   +1y
a panhandle is attached to a frying pan, a panhard bar is attached to your truck.
jmn444   +1y
you can adjust it (usually) if it's only hitting on one side. You'll have to take it off and adjust the ends of the bars to make it fit.
Dragthatchit   +1y
u can adjust the "panhard" bar usually, but dont know how u adjust a panhandle
If ur bar has an end thats threaded, simply tighten it or loosen it up (if the threads will allow) in the direction that u want the rearend to pull away from the bedside
Twisted Galant   +1y
Panhandle. thats a first 4 me ha ha ha. But like stated above it usually will have a rod end on it that u can adjust
fatboysS1O   +1y
ven   +1y
Yea there's a great Bar in the Panhandle 2 for 1 imports...$1.00 Drafts....
OH Wait a minute you mean PanHard Bar!
It should have some sort of adjustment to tighten up rear travel.
