best way to go about moldin rollpan to stepside ranger
IH
i h8 hites
about to order a steel pan from grant kustoms to put on my splash and i was wondering what ppl used to mold the glass and steel together. i know some people say fusor, but how do u go about usin that. any help is appreciated
tucky's avatar
tucky
Yea does any one sell a smooth fiberglass roll pan for a step side ranger. (If not its an idea shops)
DBLT8K's avatar
DBLT8K
i would order a metal one tack it in nice and slow and fille it with weld but one bead at a time so you don't warp it, then i would just use rage or if you are that worried about it cracking you could use some reendforced filler
bodydropped85's avatar
bodydropped85
how r u gona tack it when the bedsides are fiberglass
i would hella brace the bed were the tail gate goes(inner structure is steel) and make the bars sit flush w/ the skin and panel bond it to them then use some fusor/panel bond(i dont think panel bond works on fiberglass tho) and make some peices to go behind the skin and bedsides then kitty hair over it.
ricky@3rdshift
I am not a fan of molding a steel pan to a composite bed side, but I done it on my splash 2 or 3 times. " I kepts dragging it off."
Basically I used a pan that overlapped the bed sides and used a product for Corvette body panels, called SMC adhesive I believe and glued it on. I then smoothed the area with body filler as normal. It held good for about 2 years and I drug it off pulling in a real steep driveway laid out. I hadn't drove it in 3 months and forgot to raise it up just in case your wondering.
bodydropped85
that was what, 4 years ago yea the smc adheshive is pretty much fusor.
ricky@3rdshift
Yea it was 4 years ago almost to the day that I sold it to Ryan. It had been done the 1st time like 3 years before I sold it to him.
bodydrop99ranger
about how much does that stuff cost
layingnutz
JUST CURIOUS. IF THERE WAS A FIBERGLASS ROLL PAN MADE FOR FLARESIDE TRUCKS. YOU COULD JUST GLASS IT TOGETHER RIGHT?
