Bad Throttle Position Sensor Symptoms???
SD
Some Drunk Guy
For those of you whos TPS has went out on them, what were the symptoms?
My trucks been running like crap and it just threw the TPS code on the check engine light......????
But before I go pay for a new sensor I want to see If I have the same symptoms as you guys did...
SICKANDTWYSTED's avatar
SICKANDTWYSTED
for me it was hard to start a few times, but mostly it would try to cut out on me on the freeway. It was like it was runing outa gas like when you have a clogged fuel filter. The worst part about it was how randomly it would happen, it would run fine for weeks inbetween the times it ran shitty. and then there was the time my air flow meter went out..... whole other nightmare there lol
dalolo's avatar
dalolo
at times you'll have dead spots in the throttle and other times you'll goose it or try to pull out normal and it'll be like some one reached over and turned the key off hope this helps
later dalolo
SD
Some Drunk Guy
Ok Ok , seams like that could be it?, mine is easy to start, but if you try to drive down the street,it only runs at really low RPMS you barely have to touch the pedal,... or if you try to give it gas,it seams the fuel gets cut off and chugs spits and sputters really bad
