Audio/Video \  Amp/Sub question
Amp/Sub question
Audio/Video Q & A
views 263
replies 18
following 6
killersloth   +1y
I have a 1999 Rockford Fosgate 360a2 (360 watt RMS at 4 ohm) that I'm using for 2 10w0's. They do pretty good in my truck but get distorted at higher volumes... I was wondering if I switched to 1 10w6 and kept the same amp, how hard it would hit compared to the 10w0's... I want to switch becuase I assume it would sound better, and it would also save me a lot of space in the back of my truck.
Whats is the difference between "Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts" and "Continuous Power Rating (Competition Standard) - Measured at 13.8 Battery Volts" because the 14.4 Volts it is 450 watts RMS at 4 ohm.
Also is my amp stable bridged at 2 ohm, so I could give the 10w6 more power?
Thanks!Sorry if what I said doesn't make sense or is wrong... I'm new to car audio...
killersloth   +1y
I just noticed that it says its not stable at 2 ohm bridge... so nevermind that question...
SuperchargedS10   +1y
well the answer is yes electronics is one of those things that if its more expensive it will be better so if you want to get a 10w6 i would do it and your amp would push one just fine but i dont know about two you would take a chance at blowing them at high volume it would overheat the voice coil
killersloth   +1y
I dont plan on running two. I have 2 10w0's right now, and I want to know if just one 10w6 would hit as hard as the 2 10w0's with the same amp.
Thanks for the quick reply
rickster6924   +1y
acording to JL audio the 10w6 is a dual 4ohm sub so u can't hook it up at 4ohms to ur amp it can only be hooked up at 2ohms or 8ohms so u might want to get a class d stable at 2ohms
killersloth   +1y
Well aint that a bitch... What would you recommend for a different sub that will be just as good? I would rather not have to buy a new amp, since I'm trying to keep cost down...
killersloth   +1y
What about a 10W3V3? How would that hit compared to what I have now?
rickster6924   +1y
10w3v3-4 should work just fine just make sure u get a single 4ohm or dual 2ohm if ur going to use the same amp
jaredmxg   +1y
Have you ever thaught about the box creating the distortion? what kind of enclosure are they currently in.
killersloth   +1y
I'm not sure what box it's in. I bought the whole thing used from a friend's sister... It's just a standard 2 sub box, not sure on air volume, but I would assume it's right.
The 10w3v3 is 4 ohm, well you can get 2, 4 and 8, but I would get the 4 for obvious reasons. So do you think it would do almost as good as the 2 I have now? I dont want to spend the money and have less bass, well not too much less. I might just do it for the extra space in the back, and if I do get it I would get the JL box so I know it has the right air volume.
Thanks for all of the replies
