what to do to make the front lay 97fs
SiLveRProJecT
so we have got the back to lay...alot of welding and cuting....anyhow, my attention has turned to the front....i am going to cut the upper cups.....they are from aim...so they are rather tall.....but it seems that i only have an inch or twotill the top of the wheel well...but i have about 3 1/2 till i lay frame....any hints will be helpfull
2LOW4U's avatar
2LOW4U
Do you have drop spindles?
bdroppeddak's avatar
bdroppeddak
geez you are gonna have to get smaller wheels and tires.........
Forever Draggin's avatar
Forever Draggin
drop spindles? cut the wheel well out
bdroppeddak
i think this guy is in the same boat as you....
95LayingBody's avatar
95LayingBody
Also on that year truck you will have to move the exhaust that goes from the drivers side to the passengers. I am in the same boat. Then the crossmember will need to be welded on and the 4 bolts taken out to make it lay all the way. This is all after that fact of drop spindles and cut the wheel well out
95FullSiZE's avatar
95FullSiZE
yeah its a stupid bitch. Ive been dragging the fuck outta my Ypipe when it comes off where gonna run stainless pipe straight back into 40series flowmasters. Depending on the wheel size u gotta tub the firewall. I really wouldnt just weld the tranmission x-member solid. Take it out and put sides on it and move the bolts up to the side of the frame. You may have transmission problems someday and want to change it without pulling the whole engine.
STUD1Y's avatar
STUD1Y
what you need to do is cut those cups down probably.
drop spindles.
remove the inner fenders
trim the fender lips off
get a shorter y pipe made or some custom duals made up for the truck...
and DO NOT FUCKING WELD the cross member in.
you can either make brackets to have it bolt in from the sides, or weld some studs through the frame to hold it in, and put nuts on them, or run carriage bolts.
I had the same wheels / tires on my chevy fullsize and it lays out nice on those.
NtotheIZZATEDOG's avatar
NtotheIZZATEDOG
Edited: 6/16/2006 10:25:46 AM by NtotheIZZATEDOG
can you hot glue them in? or is fusion pressing better?
