no camber
no camber
CLNSHAVN
well for some reason the shop that my truck is at is tellin me i have to get new rims cause my shits not camberin and wont tuck. I got chasis tech control arms and spindles, and everything things workin good except i got like no camber. Why is this?? If anyone can help me i would really appreciate it.
down2earthdawg's avatar
down2earthdawg
theres no camber because you have the lower control arms and spindles. they both correct the front end geomotry there for when you lay it you lay it out there is very little to no camber at all. It would help if you showed us pics.
CLNSHAVN
ya but the lower control arm that chasis tech sent me was damn near the same as the stock one. So what happen if put the stock lowers back on would that give me more camber??????
TwistedMinis's avatar
TwistedMinis
Its quite possible. Lay it out on the stock components and you should have camber. You may have to pie cut the upper arms for them to lay, and depending on how you do this you may shorten your arms which would add more camber. A little bit goes a long way.
Related Discussions in Isuzu
