sleepy
The last couple I have set i have leveled the lower mounts and tacked them in place, then used pieces of 3/8" all thread and nust and washers to set the upper plate 3" higher. This way you can set the rearend as far up as you need it to lay, then start building the upper mounts to fit. that will keep them in place and aligned while you work.
