tubs fo dubs
Twotipped@aol.com's avatar
tubs fo dubs
Low_SST's avatar
Low_SST
i was just wondering if you guys do anything to connect the tub to the outter bed skin when you install them?
Low_SST's avatar
Low_SST
anybody
Severed701's avatar
Severed701
arent they usually attached to the inner bed wall?
Forever Draggin's avatar
Forever Draggin
weld it to the inner bed wall, u can grind it down and run ur finger with some caulk or sealent if u like to smooth it out
BaggedMazda87's avatar
BaggedMazda87
Yeah, DEF DO NOT weld it to the outter skin!VERY big mess!Inner walls, bed flood, bed rails...Pretty much anything on the bed EXCEPT the outter walls!
jmn444's avatar
jmn444
what i did up front, to minimize the possibility of dings from rocks, was rivet some garage door rubber to the edge and let that push against the fender, should work good in back too!
Dragthatchit's avatar
Dragthatchit
not as bad idea...u could go to ur local interior supply store, and they usually carry an assortment of universal rubbers in different sahpes and functions, they might have something that would work for ya their as well. Seam sealer isnt a bad idea either, so either way ud be just fine!!
