Chevy/GMC Trucks \  edelbrock intake help
views 137
replies 5
following 5
TooLowSdime   +1y
i have a small block 350 that my carb took a poop. it has a edelbrock carb and intake manafold on it. my problem is that the two back bolts broke off when i was trying to change the carb to fix it. well i drilled them out and used e-z out bit to get the bolts out. we were able to get one bolt out but the e-z out bit broke off in the other bolt. now every drill bit i use to try and drill it back out just gets rounded off because it doesn't want to drill through the hardend steel. any ideas? i know i could just get a new intake manafold but that's kinda more work then i wanted to deal with. thanks.
lowc10   +1y
does it not have another set of holes you can use? I know my rpm only has one but my old one had two sets of holes
lyinlow   +1y
if you have to get them out find a local tool company and get a carbide drill bit.. it will drill hardened steel.. it can either be a solid carbide drill or get a higher quality masonry bit thats carbide tipped... hope this helps
TooLowSdime   +1y
na its only got one set of holes. thanks lyinlow. i figured there's got to be some kinda drill bit that would drill it out. i tryed using titanum drill bits bit it just toasts them. how much do you think carbide drill bit would cost?
c10onfire   +1y
I've seen someone weld another bolt on top of the broken one and then back it out that way...
dooredZoo   +1y
^^Ditto, thats what we always do.
