Chevy/GMC Trucks \  87 s-10 bodydrop question
views 128
replies 8
following 5
Skizot   +1y
well guys heres the deal, im bodydropin my 87 s-10. Everything is goin good except for my steering shaft getting pinched between the upper control arm, and the exhaust coupler. ive had to notch the arm for the clutch master cylinder to clear. im thinkin that ART uppers will help my problem. If anyone has done this befor plaese help me out to find a solution.
no1lowr   +1y
they would clear that up nicely actualy, they mount out of the way if im not mistaken, get at me and we can get you going if you need a set, or information feel free to call 661 492 1141
Skizot   +1y
would they still clear the clutch master cylinder?
built to drag   +1y
skizot, i got a set from Josh at rail it last week and they work great. I ordered them and had them in two days just as promised. i had the same problem and they worked out well. good luck BUILT TO DRAG
Skizot   +1y
im going to order them on tuesday. I just hope the clear the master cylinder, i dont want to rebuild new arms. preciate the help man
built to drag   +1y
i had a problem with my headers clearing too and they solved that problem. i m in the process of a 350 swap. Another good thing is they clear the strater better on the 350, i ordered the upper and lowers. i had djms prior and they were very cumbersome. alot of unsprung weight too. the art arms are nicely made and engineered well. Some of the other arms out there are just too heavy duty, its over kill and actaully wouldn t have worked as well in my situation. you should consieder uppers and lowers. to keep proper balljoint alighnment as well. good luck
Skizot   +1y
yea maybe i should get the whole set. i dont know what to do right now.
SoLow03   +1y
Yeah tubular arms will definitely clear up your problem. I'm running ART's and I don't have any problems.
Chris
Acro Texas
Skizot   +1y
well i got the uppers in, they look like they will clear the steering shaft, but first they have to clear the master cylinder. if you have any suggestions let me here em. Later
