3-stage paint ???
3-stage paint ???
eks10BDRG-N avatar
eks10BDRG-N
was wondering if I need to wet sand between the base coat and the transparent color? if so with what grit wet/dry??? and how many coats of each color should i do??
eks10BDRG-N avatar
eks10BDRG-N
bump
sublime avatar
sublime
spray the base until you have coverae, about 4 coats. spray a card along with the truck. you don't need to sand between the base and mid coats. just spray a let down panel on the card you already put base on. usually anywhere from 1-4 coats depending on the color you want. it will get darker with more coats. when you decide on the number of coats you want spray them on and then clear it as usual.
eyecandy customs avatar
eyecandy customs
the only reason u would sand between mid and base coat, is if it got some dirt in it, if you are doing a complete, keep your passes nice and even and the same on both sides, and from front to back, so you dont get "tiger stripes" or darker and lighter areas........ if you are spraying a pearl white 3stage, take a spray out panel and spray it just like you would the car panels, and do ruffly 2 coats of pearl on top of the white, then take it outside and spray it with the pre-cleaner to get it wet so you can see how yellow it gets, if you want it darker/ yellower, spray the panel another 2 coats, take it outside, spray it again, and continue this process untill you get the desired color you like, and spray the whole car with the same amount of coats of pearl as you did the spray out card....
Scotty
eks10BDRG-N avatar
eks10BDRG-N
cool guys, its a dark color...... thanks for help
eks10BDRG-N avatar
eks10BDRG-N
Originally posted by slammed 4runner man
the only reason u would sand between mid and base coat, is if it got some dirt in it, if you are doing a complete, keep your passes nice and even and the same on both sides, and from front to back, so you dont get "tiger stripes" or darker and lighter areas........ if you are spraying a pearl white 3stage, take a spray out panel and spray it just like you would the car panels, and do ruffly 2 coats of pearl on top of the white, then take it outside and spray it with the pre-cleaner to get it wet so you can see how yellow it gets, if you want it darker/ yellower, spray the panel another 2 coats, take it outside, spray it again, and continue this process untill you get the desired color you like, and spray the whole car with the same amount of coats of pearl as you did the spray out card....Scotty
man that silverado is sick. good work
crippled4life avatar
crippled4life
basecoat sticks to basecoat no need to sand unless trash
