Isuzu \  rodeo measurment
rodeo measurment
Isuzu Make Specific
views 672
replies 12
crippled4life   +1y
any one have the measurement from the front of the back door to the rear of the hatch?thanks
shortrodeo   +1y
ok so i measured from the front of the back door to theback of the tailgate. right where the boddy starts to drop straight down, about 2-3" down from the top of the tail gate. It measured 76"
hope thats what u wanted. if you need any other measure ments.. lenght wise i got kinda a rodeo sittin in the garage.
crippled4life   +1y
just the man i figured would come through..thanks bro
crippled4life   +1y
miles hey do u think u could measure the inner wheel well lip in the back from wheel well to wheel well.thats if it hasnt been heavily modified thanks bro
shortrodeo   +1y
Hm you talkin about tryin to measure from the lip of the fender to the lip of the fender to see how wide an axel/rim combo you can stick in there?
Cant realy get that measurement cuz there is no way to get a tape across right there cuz of the irs and floor and stuff. but i can tell you that my IRS is 59" wide from face of hub to face of hub and with the NC and 45+ offset 17x7.5s i have less than 1/2" clearance on either side.
Hope that lil bit of info helps
crippled4life   +1y
thanks man that is the partial reasoning for the measurement..what irs did u use..im running 93 lexus sc300 most likely..could still change.waiting on measurements for that...would rather shorten than extend
draginzuzu   +1y
I CAN GET THE MEASUREMENT FROM THE INNER LIPS ...DAMN THAT SOUNDED DIRTY. My rodeo sittin on the ground with no frame Ill let you know tomarrow
crippled4life   +1y
thanks bro
crippled4life   +1y
miles was your irs shortened or did u find one exactly 59in. .cuz the lexus one is 59in but i dont want to run it if 17's with a 45+ offset is all i can fit.could u go bigger if u wanted to.the spacecab from rotor to rotor is 57.5.think i might shorten any opinions
shortrodeo   +1y
59" is how wide a rx-7 IRS is. I dont know how easy it would be to shorten the halfshafts on this thing else the metal swingarms would be real easy to bring in and in effect make the rear end narrower.
I personaly cant go a bigger wheel, but if you dont go to the door you are going to have a little bit more room width wise.
But anyways you can get 20x7.5s these days in a 38+ offset, i cant say for sure if that would fit on your ride i guess it depends on how low you are going to go with it.
If you going to run a solid axel, i know that Isuzusponge with the red rodeo is running some oldschool space cab axel thats pretty narrow, he even had to put spacers behind his 20s cuz it was so narrow.. you might want to see if he can tell you what it was from and how wide it is.
