Mazda Trucks \  Pinion Angle?
Pinion Angle?
Mazda Trucks Make Specific
views 633
replies 15
following 13
BaggedB22   +1y
Ok the mazdas getting a 98 mustang 8.8 disc brake rear, only problem is i forget what the pinion should be set at ride height. With a 1pc driveshaft.... Help please! Thanks in advance....
BaggedB22   +1y
anybody no?????
mindlissmetalfab   +1y
what is the transmission at?
Dragthatchit   +1y
+/- 2/3 degrees of ur transmission tailshaft
TwistedMinis   +1y
Basically its just not supposed to go straight with the driveshaft, because it will destroy the bearings. I set mine at the same angle as my motor/tranny. Which was a positive 2 degrees.
whynotfab   +1y
equal but opposite angle of the trans, check this pic out but ignore the #s, theyre just for example:
http://carcraft.com/howto/91758/
Dragthatchit   +1y
XACTLY!!!!
BaggedB22   +1y
What do i measure off of to get the angle of the tranny my trucks v8ed, i get what your saying though ricky
jsnpdy22   +1y
measure off the tail shaft on the transmission
bdroppeddak   +1y
wrong!
it should be equally opposite of your transmission, and the ride height should not allow the u-joint to have a 0 degree working angle, because the joints need at least 1/2 degree working angle to properly lube the needle bearings.
