changing lug pattern
HS
hybrid showoff
was wondering if there is any way to change my lug pattern from 4x114 to 4x100. or basically going from my accord lug measurements to a civics lug measurements. can i swap rotors of of a civic or GSR?
detached's avatar
detached
sup bro id think youd change the hubs or have them re drilled.. hows the accord comming anyways??
HS
hybrid showoff
accord is still torn apart chillin in the garage, have had money to do anything to it...half my parts are on a 4 month back order too!!! but the air is all reworked with all new parts cept for the rear cylinders. they still leak out hte bottom of the cylinder for some reason.
what hubs could i swap too though?
detached's avatar
detached
id think you could do honda but you might need to change the whole spindle.... id holla at layinrocker aka john on here he redrills a lot of hubs on here. for a good price too
detached's avatar
detached
if they leak out the bottom id think either the shafts are scar'd up or maybe bent or the seal went bad on the how to section there is a how to on putting new seals on the cylinders.
HS
hybrid showoff
searched for john but couldnt find him. layinrocker came up twice but neither has a real profile persay. do you think any civic hub would fit?
HS
hybrid showoff
HS
hybrid showoff
noone else knows?
detached's avatar
detached
no clue bro id try the honda forums & inorder to find layinrocker id just click on your name & then on the webaddy at the to where your name will be enter his
