TwistedPhil
The engiine driven would definitely be the best bet, if you can squeeze it on your Mazda. The Oasis is almost just as good, but everyone's right about the downsides- oil, current draw, etc.
The 2 Zeniths could probably be run without the dual batteries, but a better alternator will be a must. With 12 gallons, you'll want to give the AZs a rest when it's hot outside- they'll overheat and wear prematurely. Good luck!
-Phil at FBI
