Air Ride Suspensions \  Problem airing up.....
Air Ride Suspensions Q & A
views 294
replies 10
following 8
ALL 20S   +1y
My Chevy LUV truck had 5/8" hydro hose and was airing up. But today, my dad and me changed to 1/2" airline, and now the front will barely air up. When I hit the switch, the valves(herion)will click and sound normal. We are stumped?
krayla   +1y
Check everything for kinks?
BaggedB22   +1y
Yea deff check for kinks, nothing chould be clogging the line could it?
ALL 20S   +1y
I forgot to say that we only re-plumbed the front so far, we didn't get to the back due to the problem in the front. The airline is an almost direct connect w/the valves, I went out and checked and there is no kinks. I'm gettin stressed out, lol.
whynotfab   +1y
Do you have a tank gauge? If not maybe pressure switch wiring came loose or something, and you dont have enough PSI. If you've checked that though.. maybe some teflon stuck in valve?
pewter2000   +1y
you may need more psi ,now cus of the smaller lines
rrusd   +1y
Jusrt a thought, but could the valves be backwards??? Sometimes it is the simple little BS like that , that will drive you APE SHIT trying to figure out. Good luck with it.
ALL 20S   +1y
Thanks for all your input fellas, tomorrow when we go back out in the garage we are goin to check the psi.
Russ-D - That was actually the first thing I said when the front didn't go up, lol.
NCsteven   +1y
I thing the valves are wrong!
ALL 20S   +1y
The front still won't raise up, but the back raises up fine. I checked the pressure switch and its a 110-145psi, we even changed the switch to a new one that is also a 110-145psi and still nothing. Any ideas?
