Chevy/GMC Trucks \  2006 Colorado Baggin ?
views 242
replies 12
following 10
mindlissmetalfab   +1y
Does anyone build a kit for these trucks yet? Its an 06 Quad Cab. Guy doesnt want to cut up the truck really, just wants it bagged for a reasonable price, so I'm leaning towards a kit if there is one available, but havent had any luck finding one yet...Also is there a colorado/canyon forum?
baggeddime   +1y
clean cut creations make alot of stuff for them
Don't have much for baggin stuff other then the trans crossmember from what I can see on the site?
jbaker72157   +1y
I don't know of any kits out there yet
yeah i thought I had heard ART was developing one, but never heard if it was completed. I'm sure AIM makes a full bolt on though. haha.
But yeah, I guess I'll figure out whats needed with these trucks to build from scratch...
Can you keep the stock tank, and can it be raised enough to bring it above the frame? Is there room to build a good 4 link out back or is the tank in the way? Maybe a wishbone setup?
How much work is there up front...bag it like a torsion bar truck i guess, but how about underhood relocation if he wanted to lay it out? thanks guys
jbaker72157   +1y
Edited: 7/5/2006 11:17:34 AM by jbaker72157
up front the abs, coolant overflow, washer resevoir, fuse box, and battery have to be relocated. I believe you can raise the tank enough to clear,you should be able to run a wishbone. how much cutting is he wanting to do? o, and if its a 5-speed, you will have to tinker with the clutch resevoir a little bit
Does the PCM or any other computers/wiring need to go? If not, maybe this won't be too bad afterall.
settintrendz   +1y
this truck will lay full frame on 22s (coddington shadow 6s) front and rear. stock lowers, stock spindle, stock balljoints, STZ uppers. we did "z" it and raise the gastank cross members. but if you wanna lay front and rear x-members, we do offer the upper arms and tranny x-member. let me know if you need any help or if i can answer any ?'s.
clean cut creations   +1y
IM sent........
The words "dosen't want to cut it up" and "baggin a colorado" should NOT be used in the same sentence...........
