Dodge Trucks \  Dodge Ram fuel problem
Dodge Trucks Make Specific
views 355
replies 10
following 7
railinisuzu   +1y
I have an 01 Dodge Ram with the 5.2 in it. I took the stock gas tank out cuz I drug it too much and got a 20 gal fuel cell, mallory fuel pump, and mallory fuel pressure regulator. the first few months it worked fine, then my truck started runnin crappy. I did the key thing and checked the codes and it showed multiple cylinder misfire and #s 6 and 8 not firing. So i did what anyone would do and put a tune-up on it new plugs, wires, cap and button. I erased the codes and reset my regulator back to 55 psi which is what I was told to set it at and it idles at about 600 rpms. well it is still misfiring on those cylinders, any ideas?
loudciv   +1y
i think your pressure is wrong. my buddy had similar problems w/ this dakato r/t. call the dealership & see what the pressure should be.
railinisuzu   +1y
idlin in park then revin up is fine it only starts acting up when I go down the road and when I floor it god know I'd get passed by one of them motorscooters crippled people use at walmart
loudciv   +1y
jackson-vc   +1y
the mallory pumps are way too weak, the only external pump strong enough for the dodge engines is the hypertech 145 power pump
railinisuzu   +1y
did you have to run a regulator on yours? and do u think thats y the computer is reading that #s 6 & 8 cylinders aern't firing?
Low_SST   +1y
there are a number of things i would check along with that...
Blown intake plenum gasket will cause pinging and detonation in cylinders 7 and 8
clogged cat can cause a bogging down effect under acceleration. (there is also a recall on this and it will cover aftermarket one if you have already had to replace it)
the best plugs byfar have been the autolite 3923 and at the same time there is a tsb about plug wire routing causing issues.
i would also look into the fuel presure and see if that may be the issue.
railinisuzu   +1y
thanks big joe i've ben thinkin that it could be the cats but wasnt sure
cantlooswit22s   +1y
i have a msd exturnal pump,barry grant regulator.i dont remember wat the psi is.buti have it set there...ill check fo you in a lil while,gota get under it anyway.mine runs fine at idle (most of the time,unless it sits for a while),give it gas,it moves.i got codes goin,but not from this.
rangerrudy   +1y
We put a fuel cell in a Yumuggn's durango with a 5.9l and the recommended fuel pressure on it was 48 psi! Try turning down your fuel pressure so it doesn't flood the cylinders and cause a misfire!!
