what does it take for these trucks to lay rocker ? just a z or do they require an actual b/d? 7im sure you have to rework the tranny tunnel as well. any ideas or help would be appreciated
I
InternationalDave
It requires a Z, and some sort of body drop, now you may be able to get away with lowering the body mounts, but I'm going to stock floor mine 2 inches and cut and roll the rocker...
acromexicant
damn bro your truck looks b/d already , sic !
I
InternationalDave
haha yeah it lays pretty low, but's an illusion in the gravel, the pinch sits about an 3/4's to 1 inch off the ground so it does require a bd, also the rear bed mounts are bad and sag the rear f the bed which also gives the illusion of a little lower
86RED
THE EASY WAY TO LAY PINCH IS TO Z IT THEN CUT ABOUT AN INCH OFF THE BOTTOM OF YOUR FRAME (AFTER YOU REINFORCE IT). THAT SHOULD PUT THE PINCH IN THE DIRT.
