Brake Master Cylinder on 720
phil@lowdowncustom.com's avatar
balcar's avatar
balcar
Well, after trying to figure out where to put a brake booster, i'm out of ideas. I don't have enough room in the firewall (even a hardbody one is 2 big), thought about extending the tube to the core support, but thats a no go, and not enough room to put it under the dash, or behind the cab (since exhaust is on drivers side also) I am able to put it all together without a booster though, Anyone else run theirs without a booster? I can put it lower on the arm to get some more leverage, to help compensate for not having the booster. Just wanted some ideas if anyone else has done that.
TwistedMinis's avatar
TwistedMinis
In order to run it without the booster, you need a manual master cylinder. Theres got to be enough room to move it though right?
I made a new mounting flange for mine to move it up an inch, and over 2.5".Then modified the pedal to put it where I wanted.
bdroppeddak's avatar
bdroppeddak
back when i built my poop log 720 i moved the booster and master cylinder around to clear, it layed 17s easy with like 1.5" cut off the rocker.
