Fuel Pump
Fuel Pump
BM
Big Mark
Could someone recomend a fuel pump for a carb engine for me. they just confuse me. i dont know if you can get too much fuel flowing or what. any light shed on this topic would be a help
Mark
Pa Pa Dragger's avatar
Pa Pa Dragger
Mark, The main thing is having a pump that flows enough liters per hour to support the fuel requirements of your engine. Remember, you have a return line back to the tank so whatever fuel the engine does not use, is returned to the tank. What are the specs of your engine? I have a 330 hp 383 small block in a 90 Chevy truck with a 150 shot of NOS and am running a Walbro 220 lph in tank pump but my engine is fuel injected. Check with Walbro's site or call them with your engine specs, they can help you in getting the right pump. GOOD LUCK!
lyinlow's avatar
lyinlow
Edited: 7/8/2006 6:21:50 AM by lyinlow
i have a triangle engineering fuel cell running a inline mr gasket micro electric fuel pump.. its the smallest overall sized fuel pump i could find its workin perfect on my carbed 302 its 4-7 psi 35GPH
BM
Big Mark
i am running a 302 stoked to 327 on dual carbs. lyinlow i think that mr gasket one sounds like the one for me. about how much is was it.
Mark
