hey can i just tee off that brake valve in the back on the frame
1989dangeroustoy
hey can i just tee off that brake valve in the back on the frame,it mounts right were the notch would go
framescr8pintoy
im assuming you mean to get rid of that valve, yeah you can, did that to mine about 9 yrs ago. havent had any problems.
toysrus
all I did was extend the brake line and mount the proportioning valve further back on the frame. Works good for me
TacoFel
Remove one line from the valve to the T up front and plug the hole and throw that thing in the trash.
sitnlow4life
what?do you have any pics?
TwistedMinis
Thats a load sensing proportioning valve. You can shorten your line and run an adjustable one, and wrap the flexible line around to the axle. Or, you can get a proportioning valve from a 79-83 Toyota for about $10 at a junk yard, and its set up for the right flow already.
