99 Ranger w/ Fuel Pump problem, Need Help.
HOMETOWNRACER
I have a 99 Ranger w/ the 3.0 V6 w/ flex fuel and I can't get it to start. I had a fuel cell built to use the OE fuel pump and sending unit. My problem is that the OE fuel pump does not send any fuel. Is there anywhere I can get a aftermarket fuel pump/ sending unit that will work with my motor?Any help would be great.
shavedgalant03's avatar
shavedgalant03
try rangerpowersports.com
low99maz's avatar
low99maz
Why not just go to a junkyard and get a new fuel pump assembly, you can most likely get a whole tank with the assembly inside for @75$. I wouldnt switch over to aftermarket parts if you dont have to. Got any pics of the truck?
bodydropped85's avatar
bodydropped85
Edited: 7/9/2006 6:31:54 PM by bagged85
did you check the relay? it could be bad. also check the inertia switch under the pass side of the dash and make sure it isnt tripped. also u can buy just the pump from the parts store and put it on your whole assemble if it turns out to be bad.
couldbelower
i had the same problem for a litel bit and ended up just geting a new pump from autozone. it easier to just stay with the stock setup i think...but its a returnless system so just make sure all ur wiring is good. most lickley a dumb mistake, not the relay
