Can you convert the a/c compressor on a fullsize chevy?
I have a viair 450 but want to use it as a backup and run my a/c compressor as my main air supply, its all there just need to know if it will work before I ruin anything.
Recre8tor
I am told that you can do it, but I am not sure how you lubicate it??? I have an onboard that works great, but it uses oil to lube it self. Freon is the lube agent in a air compressor. So what will it use to lube.
jhudson23
Edited: 7/10/2006 5:15:31 PM by jeremyhudson
yorks are the best
91 drggn dime
you can use the sanden, you just need an external oiler that gives oil to the compressor.. just keep it full daily.. a friend of mine has on one his 96 bd'ed tahoe
ProHopper
ot potter, I heard the same thing about the oil, maybe I will go pick up a york and make up some brackets orilley has yorks for 90 bucks!
