Toyota fuel cells
N
Toyota fuel cells
toysrus
Can you toyota guys send some pictures of your fuel cells. Just trying to see some different installs. Trying to figure out what do do for my truck. Thanks
time1's avatar
time1
I kept my stock tank, i just moved it to the back of the truck between the frame rails. there is a pic in my profile.
2lowtoy
here is my stainless tankhere is my buddies tank. He is the one that built mine
sitnlow4life's avatar
sitnlow4life
Hey I took a look at your pics nice set-up.I have a question for ya.What can I do about the feed line the 2 fittings on it are sooo rusty they feel like they are gonna break when I try to losen them with line wrenches.I soaked them with pb blaster still no good. Any ideas? If I break the top one I will have to buy a new pump for the tank. If I break the bottom one its hard line all the way to the front. Thanks again
time1's avatar
time1
Keep tryin...mine were tight. The only way your gonna get them undone is bustin them loose.
sitnlow4life
Hey man thanks alot
I am assuming once I get them loose they are barbed on both ends and you can extend them with rubber line?
sitnlow4life
Hey I was just looking a the one pic in your profile.
Looks like all you did was cut that line that is inbetween the 2 nuts then extended it.
If thats the case please let me know then I dont need to mess with the nuts Feel me?
Thanks again
streetsweeper1
using the stock tank will help with the smog issue, but if you want a fuel cell you need an electric fuel pump. The 6AN fittings will screw right in to the stock toyota fuel line threads. You can get the fittings anywhere. Also get a tank with a sending unit. Most are GM (0-90 ohm) so you can hook up the gauge.
no1lowr's avatar
no1lowr
not the best pic but it sits in the frame rails all the way around it, underneath is some 1x1 with a sheetmetal panel make so nothing punctures it, the 5 gal tank and fuel pump mounts directly in front of it before the notch, on one side of the fuel cell there is a valve bracket and the other side a compressor bracket. hope this helps, sorry bout the quality its from my cam phone like a year ago.
