Bagged taco owners!!
15 following
bagged2dragg
hey,any of you guy that are just bagged on 18's with 35series tires... were you able to lay out without cutting your front wheel wells??? or maybe just a 5x7 square on each well...?please help
time1's avatar
time1
Edited: 7/20/2006 2:54:59 PM by TiMe_1
I dont have a bagged taco ,but ive seen one bagged with 18's on 35 series rubber and the wheel was was cut like your askin.
fatman's avatar
fatman
Edited: 7/20/2006 3:20:26 PM by fatman
i have a 95 taco runing 215 35 18x8.5 and my truck is bagged are you going to be doing a body drop
TrucksHC's avatar
TrucksHC
18s and 40 series...had to cut.
tacoboy
im 17's and 45 series, its lookin like im gonna have to cut it. I have the fenders in right now.
TacoFel's avatar
TacoFel
on a 215/35R18 you can cut about 8x10 out of the fenderwell and lay.
Twisted Galant's avatar
Twisted Galant
I cut mine out but then again I was B/D
onehightoyota's avatar
onehightoyota
sorry pal.... u gotta cut it... dont hesitate.. its ok.. thousands of us have done it. if u can pull off puttin bags on u'r truck, whats a lil trimmin of the inner fenders? take your fenders off and go to town. the more u cut the better off you'll be. u dont want anything rubbin your tires. take u'r bag out and shock off... bolt your tire and wheel up and use a jack to make the a-arm move in its full travel.. trim everything your tire comes close to. your fuse box is gonna be a problem, just remove it from the inner fender and tie it up somewhere. and be sure to push your battery forward so it doesn't slide into your tire.
onehightoyota
i'm runnin 19x9's up front with 255x35s.. i could lay on them.. but i also have a fully built front suspension and a new firewall and tubbed up front and moved the clutch master cylinder up and changed the brake booster to an early 90's model. if your truck is an 03' tacoma or greater, you will need to work on the ABS brake lines. when i changed my brakes over to 2piston calipers i did away with all my abs crap and just ran lines from my distribution valve/proportioning valve straight to the caliper. that helped me out tons... i hated all them dang brake lines goin everywhere.
bagged2dragg
what I am not wanting to move is the emissions box.. that what I would told it was called. I have an 01
