what axle should i run?
MDcrew208
I've been planning on getting bigger wheels over this coming winter and i'm thinking of just running amigo's up front and a narrower rear end.... from what i've seen i can run either a pre 86 mazda, a ford courier, or a older toyota 4x4.. anyone have any advice on which would have the best gear ratio for an isuzu.
PUPon20s's avatar
PUPon20s
Depending on what wheel size you are running... I have a 85 or older (Not IFS) 4X4 yota axle in mine and it is 2" narrower than my stock 95 pup axle. Most of the older 4X4 axles came factory with 4.10's. I have driven it with the 20's and it is just fine.
mmrcustoms's avatar
mmrcustoms
i also want some info on that my truck is tackin out at 80mph with 18's on it o can only amagain with 22's
mmrcustoms's avatar
mmrcustoms
will some one f*cking answer this
DragDatZu
wouldnt it go faster with 22s?
bagdb2200
Yea
lester622
the ratio is less with a 22" wheel since its taller so if it was a 4.10 with the 18 it would be like say a 3:73 with the 22 and it wont tack up nearly as much
Related Discussions in Isuzu
