Weight ratios.
Weight ratios.
guilty by design avatar
guilty by design
Its getting close to bagging time and im trying to figure out what bag im going to need. My question is: How much weight do you think a fully loaded 40ft gooseneck will apply on the back of the truck. The bags will already have to hold up 3000lbs (truck itself)+ whatever i throw on back.
lockone avatar
lockone
There will not be a lot of weight on your truck unless you have a 3-4 car hauler with a car above your bed, then your truck will have the weight of that car on its back. I have Contitech 3600s on the back of my dually and I can pull a loaded 3 car wedge with a Durango, ex cab Ranger, and a 720 on it with no problem.
guilty by design
Hmm, so 2 3800lb bags will hold up anything i throw on there?
dragnasty avatar
dragnasty
lockone, Doesnt your dually have a small block in it? How does it do pulling that kind of weight?
lockone avatar
lockone
That was when it had a 454 and wasn't b/d. However I have pulled that weight on flat groud with the small block before it just doesn't like going up hill. The small block I have in it now is fully built for towing with alot of lowend torque.
guilty by design
Thats what is gonna suck on mine, i build the truck to handle any kind of weight i can throw on there, but it wont wanna pull it. Ill eventually throw in a 454 with a throttle body or something.
dragnasty avatar
dragnasty
i did a motor swap with the 350 Vortec and 4L80E in my boxstyle. Its about the same as the 454 TBI that was in the truck.....still doesnt like hills....
pig rig avatar
pig rig
