What are the best weights to use when balancing 22in semi wheels, stick on or the clip on,I would think the clip on whould cause the bead to break,could someone give me some input, and what is the recommend foot pounds to tighten the bolts on the adapters, Thanks Greg
dragnasty
I would use stick on weights like the semis do. And Im not sure on the torque.
lockone
Stick on weights and torque specs should be on yout lugnuts for the 10 lug pattern. If not somewhere in the neighborhood of 95 ftlbs.
