Page 1 of 3
Mazda Trucks \  which leaf to pull?
which leaf to pull?
Mazda Trucks Make Specific
views 274
replies 20
following 13
usmcperez   +1y
I just dropped my truck 3" in the front and 4 in the rear, but as we all know it's never low enough...does anyone know which leaf spring do i need to pull out to lower it another inch or so? What effects will removing the torsion bars and bump stops cause? I plan on baggin her sometime in december...
dragwithme   +1y
Edited: 7/25/2006 7:16:45 PM by dragwithme
Edited: 7/25/2006 7:16:12 PM by dragwithme
just stop and save for a good drop kit bro ...next thing you know it you will be ridding around with one leaf and that is not safe ....
usmcperez   +1y
I don't plan on driving her around on just one leaf, i just want to drop her another inch until she gets her bags....anyone know?
usmcperez   +1y
Shackels? What do you mean?
minitruckpunk   +1y
the things that your main leaf bolts too. if you want to go low just monoleaf it.(as in pull all your leafs except the one atached to the shackles.
dragwithme   +1y
Edited: 7/25/2006 7:26:34 PM by dragwithme
Edited: 7/25/2006 7:23:37 PM by dragwithme
LOWERING SHACKLES
JC Whitney Price: $49.99 - $74.99
Be the first to review this productLevel trucks without sacrificing ride quality! Lower rear approximately 2-1/4" on Chevy/GMC models, 2" on Dodge & Ford models Relocate rear leaf spring and reduce difference between lower front end and higher rear end or close gap between fender well and tire. Use with front lowering springs to lower entire truck. Polyurethane bushings and instructions included. Sold in pairs.
usmcperez   +1y
HOw much lower will it bring though? Hate to sound like a dumbass but those are pictures of--
stockfloored85   +1y
depends on the vehicle, at least keep the very top and very bottom leaf.
minitruckpunk   +1y
my first mazda was monoleafed for atleast 2 years of full time beat sessions so i know they'll hold up.
madlowmazda   +1y
pull the leaf without the brackets on it- the second biggest. The order goes, main leaf, second biggest, third biggest with brackets and helper/ small leaf. I did this on my cab plus, and I also put on 3 inch drop blocks, and shaved the bump stops in the rear- leave just a small amount of rubber and put them back on- so when you hit a big bump it won't be a metal to metal klank when you axle hits the frame. Also be sure to adjust your brake lines on the axle down just a tad- or else the brake lines will rub when the truck bottoms out. Check your exhaust pipe too for clearance.
I would never drive a truck without torsions unless it's bagged. To get more drop in the front, flip the ball joints, use shorter shocks, and cut the lower bump stop bracket off the frame- you will have to cut it off later anyways for bags. be sure to trim the top of the upper shock tower for clearance for the upper control arm- it will hit it on big bumps.
