talon seats in an s-10
superstan avatar
superstan
ok i have a 88 s-10 4 wheel drive. i have access to some egale talon. its an 91 i think. anyways i want to know how hard would it be to put the seats in there. i know ill have to build a console. what will it take to build one. has anyone done this before. the seats and the console. how much lower would i set in the cab. thanks for the help.
bowtied avatar
bowtied
I dont know bout s10's but i put some honda accord buckets in my fullsize chevy and it need 4" spacers under the seat to put me up at the right seeing hieght. Just get two 2x4 wood post's and two 4x4 wood post's and put em under the seat then sit on em and if you need an extra couple inches find something to fill the gap. It's all just measurement. Find somethin to mock the seat up high and then sit on it if its right then measure it and thats how high you need to build a bracket. Im just gonna use square steel tubing and bolt mine up. But the 4x4 posts i used were good for mock up and good for a pattern to use while i build the steel brackets. Hope this helps sorry its so long. If not sorry for waisting your time. Good luck. Just remember measure it and you should be fine.
superstan avatar
superstan
thanks man. im steal debating wether to do it or not. i got a buddy that can build my brakets. id like to just bolt them in if i could but probably do need brackets. ill check it out thanks man. what about a console u ever built one?
chevrolayd avatar
chevrolayd
I had talon seats in my 88 dime std cab the rear holes in the sliders will fit flat on the rear lip in the floor the front holes you need to make brackets for. They give you tons of room for a console and they are pretty comfortable
