67-72
purplekush avatar
purplekush
looking for some info on bagging the front of this.. the back.. is easy.. just gonna use the trailing arm setup in the back because its a good reliable suspension design and its gonna be front and back only.. want it to lay flat on 20"s .. my question is what do we need up front.. 2" drop spindles.. ?? can i do it just like i did my 94 fullsize and just weld in the cups and get spindles???
KEEF avatar
KEEF
On the 67-72's to lay flat frame u have to Z or raise the front xmember at least inch and a half. Other than that its real easy the upper cup is a plate that bolts in and the lower cup u can just tack in. If u dont Z or raise xmember itll lay control arms before frame.
