valve to tank
kchnorng@comcast.net's avatar
valve to tank
kursedorange's avatar
kursedorange
im wanting to move my valves to the . whats the best way and does anybody have any pics of them
whynotfab's avatar
whynotfab
This is how I have mine, and set up a few friends this way also..
Instead of a Compression fitting on the fill end, you use a Hex Nipple to connect the fill valve to the tank. (The silver thing is a mini-ball valve, used to control lift speed.. it had male threads, works like a Nipple) Pretty simple really.. then the other end, you can use straights/90s/45s, whatever lets you run the lines most convenient.
beloved
this iis the way mine is set up the line out of the dump valves goes under the car so that is not as loud insideIMG_2381.JPG
beloved
how do you add a pic? let me know and ill post it
whynotfab's avatar
whynotfab
beloved
beloved
thanks for the help Ricky
s10
last post by baha +1y
