Ford Trucks \  i need mechanical help.
Ford Trucks Make Specific
views 111
replies 7
following 5
jcm5   +1y
i have an 85 ford f150 that won't start.it will turn but don't start. this is what i have done so far. changed plugs,wires,checked distributor,checked compression. i am getting an orange spark to the plugs what else can it be?
time1   +1y
orange spark? I have NEVER seen an orange spark. Did you change the points in the disty?
jcm5   +1y
no
chubbs6810   +1y
some of the older fords ahve a fuse block coming off of the battery check that fuse and make sure that it is
good. well what i meant to say in a inline fuse start with the easiest first
hope it helps you out
ir078607   +1y
have you checked the fuel?
jcm5   +1y
fuel is fine. new carb,lines and filter. the fuel shoots out when pedal is pressed
jcm5   +1y
Originally posted by chubbs6810
some of the older fords ahve a fuse block coming off of the battery check that fuse and make sure that it is good. well what i meant to say in a inline fuse start with the easiest firsthope it helps you out
would the engine still crank if the fuse was blown?
bodydropped85   +1y
check the coil. supposed to be about 5 ish volts runnin to it. only 12 on start up. that could be ur problem.
